Hey. Not sure why but it seems like Hexnode does not record a wipe action in the Audit report. Seems like an important feature to have.
@Hexnode Can you have this included?
Hey there, @Raelynn. Thank you for reaching out on Hexnode Connect!
You should be able to see a list of all the Actions executed from the Hexnode portal, including the Wipe Device action, under Reports > Audit Report > Action History.
A remote wipe action will also generate an event under Reports > Audit Report > Audit History by the name ‘Remote wipe action initiated on device’. You can use the search box to filter out any specific event.
Have a great day!
Chris Wheeler
