Windows device Management using HexnodeSolved
Sure! We manage a fleet of Windows 10, MacOS, and iOS devices here and we’re currently using another MDM for MacOS and iOS. We’re looking to have better management for Windows 10, specifically around security controls (enforcing password policies, being able to remotely erase a device, being able to easily onboard a device into MDM), and app management.
Hexnode will be able to meet your needs!
Hexnode manages a wide range of features for Windows, macOS, tvOS, Fire OS, Android and iOS devices.
You will be able to remotely enroll, set passcode rules and wipe Windows 10 devices using Hexnode. All this can be done remotely with almost no manual intervention.
You can manage and push apps to the Windows devices without having any physical access to it. Hexnode can also block the device features by configuring appropriate restrictions.
You can also encrypt the device using BitLocker to ensure the safety of the device.
Check out our help doc on Windows device management for more info.
Kindly sign up for the free 30-day trial to get more info on Hexnode features.
