Windows app formatsSolved
2 months ago
Hey everyone! Our company just added a bunch of new Windows devices to our fleet, and we are figuring out the best ways to deploy apps. What formats do you typically use for app deployment? I would love to hear what works best for you!
Replies (10)
2 months ago
We usually prefer MSIX or EXE formats for app deployment in our organization.
2 months ago
How does APPX fit into this? I’m having a hard time figuring out if the file is MSIX or if it’s just an APPX with the file extension changed to MSIX.
2 months ago
From a packaging perspective, there’s no need to distinguish between them. The runtime will automatically handle the file based on the manifest declarations. It won’t affect the deployment since both APPX and MSIX formats share a common deployment stack.
2 months ago
Can APPX also be used for deployment? What’s the difference between APPX and MSIX in that context?
2 months ago
APPX is a more limited version of MSIX. Initially, APPX was the only format allowed for installing UWP apps. MSIX format was designed to replace both APPX and the traditional MSI format for desktop applications and it is now the preferred method for distributing UWP apps, offering better security, and improved management capabilities. If you have the option, MSIX is the preferred choice for new deployments.
2 months ago
So, if I have an APPX file, would it be better to convert it to MSIX?
2 months ago
Yeah, you could try converting the APPX file to MSIX. Or, if you are using Hexnode, you can probably try adding the app as an enterprise app.
2 months ago
Just checked, Hexnode supports MSI, MSIX, EXE file formats for enterprise app installation.
2 months ago
In that case, you could use the Execute Custom Script action on Hexnode to deploy your APPX file to the devices.
2 months ago
Thanks for clearing my doubts!
