Will deleting a user from Hexnode using API disenroll his devices?Solved
5 years ago Jun 25, 2021
When deleting a user using API, do any enrolled devices also get deleted? Or would I need to send disenrolls before deleting?
6 years ago Apr 21, 2020
Yes, if the users are deleted using API, the devices that are assigned to that user will be disenrolled.
So, you need not initiate a disenroll action on these devices.
5 years ago Jul 13, 2021
A little late here but why use API to delete a user?
Hello K@ren,
Hexnode provides API(s) to customers who wish to perform some repetitive operations on the devices and users in Hexnode without using our web interface.  For example, to delete a user, the HTTP request and shell command are as follows:
HTTP request:
Shell command:
Refer to our help documentation to understand more about API.
Hope that helps
Cheers!!
Deborah Timothy
  • This reply was modified 5 years, 2 months ago by  Deborah.
5 years ago Jul 16, 2021
I was wondering what will happen if I delete the user from Hexnode. Will it disenroll the device under the user?
(not with API, in general)
@_patricia_, that’s a good question.
When you attempt to delete a user from the portal, you may choose any one of the options for the devices enrolled under the user –
● Disenroll device
● Assign to a different user
If you choose to disenroll the device, all devices enrolled or added on the portal (pre-approved devices) will be disenrolled and deleted respectively once the user is deleted. If you choose to change the user, you’ll be redirected to the Change Device Owner window where you can set a new device owner for the device.
Note: You may only delete local users. Also, you cannot delete any user set as ‘default’ under Enrollment authentication modes, Apple Configurator or DEP enrollment wizards.
Hope this helps.
Zach Goodman
