What’s new with Location tracking for Android devices?Solved
Location fetching for Android devices has got a new phase with our latest release.
With this, you can now prompt the devices to enable location services if it’s disabled or when the user disables it.
Here is where you can find this.
  • Login to your Hexnode portal.
  • Navigate to Admin > General Settings > Location Tracking > Prompt to enable location services.
  • Check the option.
However, this doesn’t work if the devices are locked down in kiosk mode.
