Web Apps outside Kiosk (BYOD – Android device)Solved
2 years ago
Hi. Is there any way to add a web app to the work group of a device enrolled as Android BYOD? Thanks.
2 years ago
Hello, welcome to Hexnode Community!
Sure, you can add a web app to the work profile of an Android device enrolled as Profile Owner in Android Enterprise. All you’ve got to do to create the web app is log in to the Hexnode UEM console, navigate to Apps > Managed Google Apps > Web App, and enter the web app details. The app can then be pushed to the device using the Mandatory Apps policy. The process has been explained in detail in our document on publishing web apps as Managed Google Play apps outside kiosk. Do check it out and get back to us in case of any further queries.
Chloe Edison,
