Weather widget not working on iPhone since last updateSolved
2 years ago
Hi, is it just me or has the weather widget been acting weird since the last few updates. I was hoping it would be fixed with the latest 16.5 update, but no.
2 years ago
Same here, it hasn’t been working properly since I updated to 16.3
2 years ago
Hello people, not here to give an authoritative solution, but from the little experience I have dealing with iPhones, these are a few things that could work:
  • Force close and open the Weather app – It works in most cases to just force the app to close and re-open it. Minor issues can be resolved this way.
  • Restart your device – restarting the device can go a long way, it can fix issues that may not make much sense.
  • Remove and re-add the weather widget – Try removing the widget and adding it back to see if it starts working properly.
  • Update the weather app – Go to the App Store and make sure that the app is on its latest version.
  • Check the permissions granted to the Weather app – Go to Settings -> Privacy & Security -> Location Services and scroll down to find the Weather app. Make sure it is set to ‘While Using the App or Widgets’ or ‘Always’. Try turning on Precise Location too.
  • Check internet connectivity – Very basic, but you never know, something as small as this could be the issue.
2 years ago
Do try uninstalling and re-installing the Weather app too. Since it is an in-built app everybody assumes that it cannot be uninstalled. But it can be done. Check out this link:
https://support.apple.com/en-us/HT211833#:~:text=Press%20the%20Digital%20Crown%20to,tap%20Delete%20App%20to%20confirm.
