vpn prompt during enrollmentSolved
One thing I’m trying to achieve is removing the “Connection Request” for the VPN connections while enrolling. I’ve removed it under the “Advanced Restrictions” settings in the policy but everytime it asks to activate the VPN.it is android
Please navigate to Admin-> General Settings-> Data Restriction (Android). You will be able to see the following options:
Prompt to activate VPN: Uncheck the option to disable the VPN prompt during the device enrollment. VPN activation is essential for enabling Mobile Data Management and data restriction policies on the devices.
Prompt to activate VPN while in kiosk mode: The option when checked, shows prompts to activate VPN while in a kiosk, without exiting the kiosk, when data restrictions are applied on to the device. Unchecking this will block the VPN prompt as well as the mobile data management on the device.
Uncheck the options based on the requirements and click Save.
Kindly use the link for more insights into General Settings.
