upload ipa fileSolved
8 years ago
how to upload ipa file and import device to download the app
8 years ago
Hi Lyric,
The detailed documentation on this topic is available on our help portal with the title Distribute iOS Enterprise App.
Can we update the app to the newer version using new ipa file?
Hai,
Thanks for reaching out.
Yes, you can! Kindly follow the below steps for the same:
  1. Navigate to the Apps tab and search for the desired app to update
  2. Click on the app
  3. Click on the gear icon on app details box
  4. Select Edit from the drop-down list
  5. Click on the option Change beside the IPA file
  6. Upload the new app version
  7. Click save
Please find more insights on the same, using the help link
Will the app be updates automatically on doing like this?
After the old APK file is replaced with the new one in the App Inventory, If the Enterprise app to be updated was pushed to the device as a mandatory app via policy, the app gets updated on the device provided the policy remains associated with the device.
You can update the app via the Actions button. Go to management > Select the device, click on actions button and click ‘Install Application’. Select the new version of the app and click Done.
Please use the link to know more about how to update the Enterprise app on Android devices.
