Update location once the user turns on the wifiSolved
8 years ago
Can you set it to default to update location once the user turns on the wifi? how it work in real time . i want to pull the location using my internal Software
8 years ago
Hi, Beth.
Apple doesn’t allow us to fetch the location right away, but we do get it when there has been a significant change in the location. For a device that is traveling, you should be able to get that with fairly good accuracy.
Have a look at this discussion to know more about ensuring you get the device locations with maximum accuracy.
