‘Uninstall Application’ – now available for macOS devices (Beta)Solved
11 months ago
If you’ve been searching for an easier way to uninstall applications from your managed macOS devices, this announcement is for you. Support for the Uninstall Application remote action has now been extended to macOS devices.
IT admins can now remove DMG, PKG, and store apps from macOS devices with just a single click.
Uninstall application remote action
