System Extensions – Revamped!Solved
10 months ago
We’re giving the System Extensions policy a makeover. IT admins will no longer have to manually enter the Team IDs or Bundle IDs of all the system extensions that should be allowed to load on the Mac. Instead, they will be provided with a smoother UI where the Team IDs and Bundle IDs are listed, allowing them to simply check the required boxes that correspond to the different types of system extension frameworks.
It’s simpler than it sounds; the feature is in its finishing touches, and we promise you’ll like the newer version of the policy. Stay tuned for the release announcement!
