Support for DELEGATION_CERT_INSTALL on Android?Solved
2 years ago
Does hexnode provide support to set delegated scopes for Android apps (DevicePolicyManager.setDelegatedScopes)?
2 years ago
Hello @mlincor, it’s good to see you again!
Hexnode does not support setting Delegated Scopes for Android apps. Could you please share the management scopes you’re looking to delegate so we can consider it eventually?
