Block user from modifying Bluetooth settings on iPadsSolved
Certain bluetooth configurations are set on my clients iPads. Can I prevent the users from modifying the bluetooth settings?
Hey, Thanks for posting.
Yes, you can. Please navigate to iOS–>Advanced Restrictions–> Allow Device Functionality. Disable the ‘Modify Bluetooth settings’ option. The option is enabled by default.The feature is supported only on Supervised iOS 10.3+ devices.
Kindly use the help link for more info on Restrictions
