Setting up a newly purchased device, OS never startedSolved
4 years ago Oct 11, 2022
Hi All
I am not an IT guru, but I am maintaining my O365, Azure accounts
I have 3 new Samsung PCs and 3 new Tab S8 Ultras that I have not started up
One is mine and 2 are for my employees, we are rarely at the same location
I have Azure AD, O365 accounts for all of use, I am a global Admin
I have an admin@ that is also a global admin
My question is what would be “best practice” is to maintain security
  1. What user should I initially start OS with
    • the Windows devices
    • the Android devices
Thanks for any support
4 years ago Dec 07, 2022
Hey Michael,
Hexnode provides detailed documentation to help you choose the enrollment method or all your device types. As you’ve mentioned that you manage your O365 accounts, you can go through our documentation to integrate your O365 account and sync all the users to the UEM portal.
Also, when deploying your devices, you can start with either Android or Windows, regardless of the deployment method utilized.
Hope this clears your query.
Chris Coleman
  • This reply was modified 3 years, 9 months ago by  Chris.
  • This reply was modified 3 years, 7 months ago by  Chris.
