Security Update 2022-001 Catalina released as a standalone installer packageSolved
Hey folks! Apple has released security updates (Security Update 2022-001) for Catalina as a standalone installer package along with Monterey 12.2, Big Sur 11.6.3 updates.
https://support.apple.com/kb/DL2088?locale=en_GB
Replies (9)
That’s weird…I don’t see security updates available on my catalina macs. Just the update to Monterey.
Click the more info link underneath the ‘Other updates are available’ text, that should show you the security updates.
You can also install it from here: https://support.apple.com/kb/DL2088?locale=en_GB
Few of the macs is automatically shutting down at some point after going to ‘sleep’ since the latest catalina security update. Anyone else facing this issue?
Nothing on my end so far. Try resetting the nvram and see if that helps.
Already tried that without luck. Have also been seeing similar issues being reported on other threads. Thanks for your inputs anyways @koen.
@ami_ra macOS Catalina Security Update 2022-001 has addressed many previously existing issues. However, many users have reported similar issues following the update. On contacting Apple Support, they recommended wiping the Mac or re-installing Catalina again.
Chris Wheeler
Reinstalling catalina seems to have fixed the issue for now. Will update here if anything else comes up.
Koen, I appreciate you sharing the details.
2 years ago
Thank you for details.
