SD Card BlockingSolved
6 years ago Mar 18, 2021
How can I disable the SD card slot on windows devices using Hexnode?
Hi Jarred,
You shall be able to disable the SD card slot on Windows devices by unchecking the option “Use storage card”, in Windows Restrictions. Please have a look at the image below:
SD card in Windows
You can apply this configuration on your devices and ensure that your Windows devices shall have their SD card slots disabled.
This feature is supported by:
  • Windows Phone 8.1
  • Windows 10 Mobile
  • Windows 10 PC
Thomas Specter
