SCEP Certificate Feature with OKTASolved
2 years ago Jul 09, 2024
Im attempting to use Hexnodes new Windows SCEP Beta Feature to pull down a cert from OKTA . Has anyone managed to get this to work? Any tips? Im trying to use it to make the machine appear as managed.
Hello @cmolina , welcome to Hexnode Connect!
Could you please explain the specific issue you’re encountering and where you’re getting stuck? This will help us guide you in the right direction.
2 years ago Jul 10, 2024
I am able to configure the scep profile acording to the instructions but the certificate request doesnt go through
I am able to get the certificate to install however it is installing on a machine level and not a user level.
Hello @cmolina ,
The SCEP feature for Windows devices is currently supported only at the device level. We will bring the requirement to install certificates at the user level to our team’s attention and keep you updated on any developments in this regard.
