Samsung One UISolved
11 months ago
Since the latest Android 14 update we are havign issues with Tablets in Kiosk mode where certain functions are not available, for example clicking a PDF gives no options on the launcher.
If you take the tablet out of Kiosk the Samsung One UI 6.0 update screen is sat waiting for you to press next, next next etc, once you have done this everything works and all apps in the launcher work fine.
We have also noticed it seems to stop out policies from fully applying untilyou run through the above.
OneUI and all other UI\Launcher type apps I can find are in the background apps and I’ve applied what permissions\configurations I can find but it’s not fixed it.
Any idea what we can do to sort this as we have too many tablets to go round manually taking them out of kiosk to fix.
Thanks
Replies (12)
11 months ago
Hello @cforster, welcome to Hexnode Connect!
We’ve raised the issue, and our team is currently looking into it. We will get back to you as soon as there’s an update.
10 months ago
Hi,
Is there any new regarding this issue? We need to push an update of an app but our devices are not able to update.
10 months ago
Hello @willem, welcome to Hexnode Connect!
We apologize for the delay.
Can you please add the following packages as background apps and give it a try:
  • com.sec.android.app.SecSetupWizard
  • com.sec.android.app.SecSetupWizard.fota.SwUpdateIntroActivity
Do let us know if the issue still persists.
10 months ago
@chloe_edison Hi, I already included these two. The problem is that is the the new background apps are not set because the policy does not seem to be updating on the devices
10 months ago
Hello @willem ,
Our team will require a few extra details to look into the case further. The support team will be reaching out to you soon for the same.
Please feel free to write to us in case of any doubts or concerns.
10 months ago
After applying I had one tablet go through fine which is a Samsung A9+, however one I am currently remoted onto which is a Samsung A8 is still having issues, the OneUI screen did pop up but then gave me the access denied message and hasnt reappeared since. I checked the devices blocked apps but nothing is showing.
10 months ago
Hello @cforster ,
Before our team can check the case further, can you please check if the following packages have been added as background apps:
  • com.android.updater
  • com.sec.android.soagent
  • com.wssyncmldm
  • com.sec.android.app.setupwizard
  • com.android.setupwizard.overlay
10 months ago
@chloe_edison I have added the below 3 that were missing, all other were already on the policy:
com.android.updater
I have also added the below as it appeared when searching for one of the above.
com.sec.android.app.setupwizardlegalprovider
Still getting the issue, I can occasionaly get the OneUI screen to appear but once you go off the first screen you get an access denied message and cant go any further
10 months ago
Hello @cforster
Thank you for the prompt response.
Our team is looking into the case. In the meantime, the support team will be reaching out to you soon for a few extra details.
4 months ago
Hi,
Did this ever get resolved?
We have pretty much the same issues with Kiosk and One UI updates.
Thanks,
Nick
4 months ago
Hi @ncosdsons
Thank you for reaching out.
I understand that you might have already tried adding the above-mentioned packages as background apps. If not, please try this step and if the issue still persists, please let us know, and our support team will reach out to assist you.
Eden Pierce
3 months ago
@ncosdsons Unfortunetly not still waiting on a resolution
