Roll out an App from Play-Store to Android without logging into Play StoreSolved
Hi, we have a small problem. We want to roll out a App from the Play-Store to the Android devices, but we don´t want to login with the devices to an Google Account. Is there a Way, to make a Store-App to an Enterprise App?
You can add the Enterprise app to the Hexnode inventory using the APK file and then deploy it to the device. Please navigate to Apps tab, click on +Add Apps and choose Enterprise app. Upload the APK file or provide the Manifest URL, fill in the details and click Add. The app can now be pushed to devices via Mandatory app policy or Remote actions. Check out the help doc on enterprise app distribution for more info.
You can also enroll the devices in Android Enterprise and push the store apps to them. The apps will get installed on the device without any user interaction. Check out the help doc on enrolling organization in Android Enterprise for more info.
