Rev up your device analytics with Custom ReportsSolved
6 months ago
We understand that every organization has its own unique data needs. And with Custom Reports, you can now tailor your device analytics to align perfectly with your specific requirements. Whether you’re looking for a way to simplify your compliance audits and expense management or dive deep into comprehensive device usage patterns, we’ve got you covered.
We also have a couple of report templates ready for you to choose from. So you can pick a template, customize it according to your requirements and you’re done! It really doesn’t get simpler than that. And if you are more of a do-it-yourself person or your requirements are super niche, you can build your report from scratch by selecting an appropriate report type.
Custom Report templates
While the customizable templates give you a jumpstart, the conditional filters help you narrow down the data. Set the filters and choose the required data columns to build reports that are tailored to your exact requirements.
To get started with building your first report, head over to Reports > Custom Reports and click on the Add button. And while you are at it, feel free to check out our detailed help document on Custom Reports for more insights into the available configurations. And if you have any questions or feedback, don’t hesitate to reach out to us any time. You can send us an email at support@hexnode.com or ping us here at Hexnode Connect.
