Restrict copy-paste capabilities between managed and unmanaged apps on iOSSolved
Is it possible to restrict copy-paste of content between unmanaged and managed apps within the context of Business Containerization. Looking for something similar to the clipboard feature in Android restrictions.
2 years ago
I don’t think there’s a specific setting in the portal as such. As a workaround, you can use iMazing profile editor to create a custom configuration profile, enabling ‘Require managed Pasteboard’ restriction in the profile payload. Then push it to the required devices using hexnode’s deploy custom configuration feature.
2 years ago
Thanks! Will try it out.
