Report option for Bluetooth MAC AddressSolved
Ideation
3 years ago Apr 10, 2023
Please provide the option to be able to pull a report of all bluetooth devices MAC addresses
3 years ago Apr 12, 2023
Hey @livewot, thank you for reaching out to us.
However, we were having a slight confusion regarding your requirement, so could you please clarify something for us first?
Were you trying to pull the Bluetooth MAC address of the devices managed by Hexnode or were you trying to find the Bluetooth MAC address of the devices connected to a device managed by Hexnode.
Looking forward to your response,
2 years ago Jul 01, 2024
Yes.
I want to run a report that would give me the mac addresses on bluetooth of all of the devices.
I would like to get
SystemName         SerialNumber           BlueToothMAC
Picking01                MDGB023939         AA:BB:CC:DD:EE:FF
Picking02                MDGB023940         AA:BB:CC:DD:EE:F0
and so on…
I would then take this CSV file and use it to create labels to pair barcode scanners to iPads.
2 years ago Jul 02, 2024
Hey @livewot, thank you for following up with your request.
I apologise for not having a solution ready for you. Your feature request has unfortunately been on hold due to lack of sufficient data on the requirement. I’ll be following up with the request immediately and will let you know about any other updates from our side.
If there is anything else you need assistance with, don’t forget to reach out to us any time.
11 months ago Jan 24, 2025
I believe this was answered by being able to added bluetooth to a column in Devices and searching/sorting for them and creating an ad-hoc report.
The goal is to get a list of the bluetooth addresses for a set of devices I need to approve on the wifi network.
Hello,
Thank you for reaching out to Hexnode Connect.
We greatly appreciate your time and patience. We understand your requirement for a customized report to display a specific set of devices with the columns System Name, Serial number, and Bluetooth MAC address.
Hexnode has recently introduced its highly anticipated Custom Reports feature, which enables organizations to generate reports tailored to their specific needs.
To create your report:
  1. Select Device as the report type.
  2. Provide a suitable title and description for the report.
  3. Customize the conditional filters to narrow down the specific devices you need.
  4. Choose the data columns: Device Name, Serial number, and Bluetooth MAC address.
  5. Click Save in the top-right corner to save your report. Once saved, you can select and export this custom report in either PDF or CSV format.
With Custom Reports, you can create tailored reports by selecting a report type, applying conditional filters to target specific devices, and including only the required data columns.
For more details, please refer to our help documentation on Custom Reports.
I hope this helps! Please feel free to reach out if you need any further assistance, we’re always happy to help.
George
