Renew Apple certificateSolved
7 years ago
I’m trying to renew Apple certificate, but I’ve got an warning that topic doesn’t match with previous one. And if I continue, I need to re-enroll all devices. What am I doing wrong?
7 years ago
Hey Watson! This usually happens when you are using a different Apple ID to generate a certificate, you have to make sure that you use the same Apple ID you used earlier to generate your apple certificate, otherwise you would have to re enroll each and every device which would be time consuming.
Frank Clinton
Hexnode MDM.
