Removing unmanaged apps from Hexnode managed iOS devicesSolved
I have many ipads given to my employees for work purpose. But they are installing other unintended apps to these devices. Can I identify them from Hexnode portal? And I need to remove them also.
Replies (7)
@alexa they will be identified as ‘unmanaged apps’ in the portal. Please check that.
thank you elfie… I found them in the portal listed as unmanaged apps in the applications tab. But there is no option to delete them now. How can I do that?
Thank you Alexa for reaching out to us!
You can handle this scenario in three different ways. Firstly, as Elfie addressed, you can convert these unmanaged apps to managed apps, and then remove them from the devices. If your devices are supervised, then these unmanaged apps would get converted to managed apps, and then you can delete these apps from the Applications sub-tab of that particular device. However, if they are non-supervised devices, then a device-end confirmation is required for converting these unmanaged apps to managed apps.
Then, you can try the next method. You can whitelist only the required applications, so that rest of the applications will be blocked from the device. If the devices are supervised, then these apps will be hidden from the device. On the other hand, if they are non-supervised, then the device would be marked as non-compliant, thus notifying the admin regarding the presence of the blacklisted app.
And the third possibility is to block the app installation from the App Store.
Hope this answers your query.
That sounds pretty cool Michelle. Let me try out these methods. My devices are non-supervised, so I guess it would be ideal to prevent app store on these devices.
@hendricks…… My devices were supervised and method one worked perfectly. Thanks for sharing this. Have a great day!
If I am opting for the third one, where can I disable app store?
Hey Elfie!
You can disable app store by disabling the option ‘Show App Store on the device’ under Policies > iOS > Restrictions > Allow Application Settings.
Disable App Store on IOS
This restriction works on iOS 4+ and supervised iOS 13+ devices.
