Remove iOS enterprise app on device disenrollSolved
How to make an iOS enterprise app removed on disenrolling the device?
Hi Shane,
Along while adding an iOS enterprise app, you can check the option Remove on Disenroll to make the app removed on disenrolling the device.
After signing into your Hexnode MDM portal,
1. Navigate to Apps tab.
2. Click on + Add Apps > Enterprise App
3. Check the option Remove on Disenroll beside Advanced Settings.
4. Select all other required options.
5. Click Add.
Hexnode Enterprise App
To install the enterprise app,
1. Go to Management tab > Select the required iOS device(s)
2. Click on Manage > Install Application
3. Select the app(s) from the list > Click Done.
or
1. Go to Management tab > Click on a device name
2. Select Actions > Install Application
Please refer to our Help doc on Distributing iOS enterprise apps for further details.
Jane McLaren
