Remove apps from dockSolved
2 years ago
Hi Hexnode!
Found this script to customise apps on macOS dock
https://www.hexnode.com/mobile-device-management/help/script-to-customize-dock-preferences-on-mac/
I want to remove specific apps from the existing dock , lend me a hand here…
2 years ago
Hello @Emersyn , welcome to Hexnode Community!
Don’t worry; we’ve got you covered.
Execute this script to remove specific apps from the dock on macOS devices:
brew install dockutil;
/path to dockutil/dockutil --remove 'enter name of app' --allhomes
If you don’t have Homebrew installed, install it using this command and execute the above-given commands.
/bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
Hope this helps. Do get back to us in case of any further queries.
Chloe Edison,
