Remotely update OS on android devicesSolved
Hi, is it possible to upgrade OS on Android devices remotly?
Hi there, thanks for reaching out to us.
You can schedule the updates on Android devices using Hexnode. Kindly navigate to ‘OS updates’ under ‘Android’ and the ‘System Update Settings’ will have the following options to choose from:
Default: The settings currently on the device will prevail.
Update automatically: Choose this option to install updates automatically as soon as an update is available.
Update during inactive hours: On choosing this option, you can set the time period between which the update should happen.
Postpone updates: Please choose this option to block installation for a maximun period of 30 days.
