Push an enterprise app from Play StoreSolved
7 years ago
Hi, I’m trying to push an enterprise app from a google play store link instead of the upload feature. Is the “From Manifest Path” supports using a google play store link?
7 years ago
Hey Jared, I would first like to explain the difference between a store app and an enterprise app, Store apps are generally open to the public and can be downloaded by anyone who has access to the Playstore.
Enterprise apps are created by an organization for the use within the enterprise only, such apps would not be available to the public via the Playstore, If you have to distribute apps available on the store you can download the APKs of these apps and then push them just like your Enterprise apps.
A manifest URL should be the direct link to the APK file, where ever it’s hosted, but the Play store URL won’t work.
