Provide more option for synchronization times with ADSolved
Ideation
It would be very helpful if more options for syncing with AD can be provided. Currently all we have is either a daily/weekly timer with a specific hour and minutes of the day, instead I would prefer one were I can set it to sync on hourly or even minute bases, example: sync every 10 minutes.
Hi Dennis,
We have a current limit on AD sync as it used for user management.
However, should you need to update the same on Hexnode immediately after updating the AD server, you can start a sync manually as well, by clicking on the settings button in Admin -> Active Directory-> Sync.
Thomas Specter
Hello,
Yes, I am aware of that functionality, however it is manual. I would rather have it sync, on a mass scale it is a really cumbersome solution. I can not provide everyone with access to it, but users are created without my oversight, so I am constantly asked to log in to hexnode and sync to our AD.
It is a user case which you may not have encountered until now, however, I am sure there are people other than me that would appreciate it.
Kind regards,
Dennis
Hi Denis,
Thank you for getting back to us.
We shall definitely raise a feature request for our team to discuss the implementation of increasing the AD Sync frequency.
Kindly email us your Hexnode account details at “mdm-support@hexnode.com”, for us to append you to the notification queue.
Thomas Specter
