Prohibit users on corporate Android devices to add another accountsSolved
Can I prohibit users on corporate Android devices to add another accounts?I don´t wanna users are able to add their personal google play account or something like that
Replies (8)
8 years ago
Liam,
It is not possible as such on generic Android devices, However, it can be achieved on Samsung SAFE and Android Enterprise (formerly Android for Work), the Samsung’s and Google’s Enterprise platforms respectively.
Hexnode MDM supports most of the advanced restrictions available for Samsung SAFE devices but the ‘Accounts set up restriction’ has not yet been released. It will be available real soon.
The Android for work integration has also not yet been made available. We are busy adding bells and whistles to a major Android release to be rolled out in a couple of months.
Stay tuned for release updates and more.
Hi Liam,
The Android Enterprise is now available through Hexnode and you would be able to block users from adding new accounts on company issued Android devices if devices are enrolled using Android in the Enterprise.
Check out these links for more information on Android Enterprise and how you can set up account based restrictions on Android devices.
Cheers,
Mike
Want the exact opposite to what @liam wants- we don’t want to block them from using their mail. Will the user still be able to use their personal email accounts on their phones if I enroll into AE?
Assuming it is company owned, I think it is better to restrict them from using corporate device for personal need.
Seems a bit unfair to restrict employees from using their email.
Not worried about the safety of corporate data?
Okay, now I am half minded. Other opinions?
Hi Majed,
The users will be able to use their personal email accounts on the device even after enrolling with Hexnode. You can even allow users to add their accounts after the devices are enrolled. Make sure that the restrictions, “Modify Accounts/Users”, (supported on Samsung Knox, Android Enterprise Profile Owner and Android Enterprise Device Owner) and/or “Add Users” (supported on Samsung Knox 1.1+), are enabled in the policies applied to the devices.
To ensure proper separation of personal data and work data, you can enroll your Android devices in Android Enterprise as Profile Owners.  Do check out our help doc to know more about restrictions on Android Enterprise devices.
Cheers!!
Deborah Timothy
