Preventing users from leaving Remote Management in iPadsSolved
3 months ago
Hey Community, our school recently launched an initiative to provide iPads to students to enhance their learning experience. To ensure the devices are used appropriately, we’ve also enrolled the devices in Hexnode and added them to DEP using Apple configurator. However, recently we’ve encountered an issue where a lot of students have been reported to tamper with their devices by altering settings and removing the MDM profiles from the devices.
Is there a way to prevent the removal of the MDM profile from the devices before they are enrolled, to help avoid these issues in the future?
3 months ago
@skylar-a , I believe that if the device is supervised you can prevent users from removing the MDM profile, though this would need to be confirmed.
3 months ago
Hey @skylar-a , the option to remove the MDM profile from the device is found under Settings > General > VPN and Device Management. Here the user would have selected the installed profile and clicked on “Remove Management” which immediately removes the profile from the device and takes it out of management. Since you’ve mentioned enrolling the devices and adding them to DEP via Apple Configurator, it seems that during the DEP configuration, you might have overlooked the option to make the MDM profile non-removable. Here’s how you can enable the option,
  2. Go to Admin > Apple Business/School Manager > Apple DEP > DEP Configuration Profiles.
  3. You can click on your existing configuration profile or click Configure DEP Profile to create a new DEP profile.
  4. Here, you can uncheck the option Allow MDM profile removal. Then, click Save.
  5. To associate the DEP profile with your devices, go to DEP devices and select the devices.
  6. Then, click on Associate DEP Profile and select your configuration profile. Finally, click on Assign.
After following the steps above, you’ll need to wipe all the devices and re-enroll them for the configuration profile to apply to each one. On doing so you would find that the user would not be able to find the option “Remove Management” under Settings > General > VPN and Device Management.
Also, please note that while adding devices to DEP through Apple Configurator there is a provisional period of 30 days during which the users are free to remove the MDM profile. To prevent this, it is recommended to distribute new devices to students only after the 30-day period has passed, so that the MDM profile cannot be removed.
3 months ago
@kylian_parker , is there a way to bypass the 30-day provisional period for the managed devices in Apple Business Manager (ABM)?
3 months ago
@raelynn , unfortunately, there is no way to bypass the 30-day provisional period for devices added to Apple Business Manager (ABM) via Apple Configurator This is a built-in safeguard by Apple to ensure proper management and control over devices that are manually enrolled.
However, if the device is purchased directly from Apple or an authorized reseller, it can be linked to ABM at the time of purchase. Once powered on, Apple’s servers will automatically apply the Device Enrollment Program (DEP) profile into the device and thus enroll it into management without any delay. In this method, there would be no provisional period and hence the user would be unable to remove the management profile from their device.
