Preventing Cross-Site Tracking on SafariSolved
4 months ago
Hey there,
Is there any way to prevent cross-site tracking on Safari for our macOS devices? We don’t want any third-party trackers following our online activity across different websites.
Replies (7)
4 months ago
Hey @emersyn
We had the same requirement and looked into ways to disable it completely. While you can manually disable it from Safari settings, I couldn’t find a way to do it using configuration profiles or any other method.
4 months ago
Actually, there is a workaround. We had a similar requirement where we needed cross-site tracking prevention for most websites but allowed it for certain domains. You can specify up to 10 domains where cross-site tracking will be relaxed, while it remains enabled for all others. It’s not a complete disablement, but it gets the job done.
3 months ago
That sounds useful—at least it ensures that only the specified domains will have cross-site tracking enabled. By the way, can this be configured using a configuration profile?
3 months ago
Yes, it can be done. If you’re using Hexnode, you can configure it directly using the Managed Domains policy.
3 months ago
Oh, that’s great! That means I don’t have to go through the trouble of creating a configuration profile myself. How do I do it in Hexnode?
3 months ago
Sure! It’s pretty simple:
  • Go to the Managed Domains policy for macOS.
  • Under the Cross-Site Tracking prevention relaxed domains section, add the domains where you want to allow cross-site tracking.
  • Associate the policy with the target devices, and you’re good to go!
3 months ago
Thanks a lot! Really appreciate it.
