Prevent my users from adding another google accountSolved
Is it possible to configure a policy that would prevent my users from adding another google account? We use Android phones
If this is a Samsung Knox or Android Enterprise enabled device, please navigate to Policies-> Android-> Advanced Restrictions-> Allow Account Settings. Disable the option Modify Accounts/Users. This will restrict the users from adding, removing and switching between the users. In the case of Android Enterprise enabled devices, the users will be blocked from adding, removing or switching between Google Accounts. Please note to associate targets and save the policy.
For more help, check out the help doc on restrictions for Android devices.
2 years ago
Are the settings changed in Oxygen 13? I cannot find the settings. Thanks!
Martin
2 years ago
Hey @martin-hogvik,
Thank you for reaching out to us and welcome to the Hexnode Community.
We are sorry to hear that you are facing issues with the account settings. But are you perhaps looking for this setting on your device instead of the portal?
We have not made any significant changes to this restriction mentioned in the thread and should still be available in your portal (Policies > Android > Restrictions > Advanced under the Allow Account Settings section). If you are still facing trouble finding this restriction, please don’t hesitate to reach out to us again.
