Possible to completely disable usb connection on iphone?Solved
7 months ago
Best case scenario would be to be able to wipe the phone on usb connect, although im not sure if its possible.
Secone best case scenario would be to disable the iphone from connecting to any usb connection.
7 months ago
Hello @hopeja82, welcome to Hexnode Connect!
We regret to inform you that currently there is no option to block USB connections on iOS devices.
However, please continue to share your thoughts and suggestions here at Hexnode Connect—we truly value your feedback.
