Platform SSO for macOS on Hexnode MDM with Google WorkspaceSolved
Ideation
2 years ago Sep 16, 2024
Hello Hexnode Team,
It’s been a pleasure to be Hexnode customer and I’m currently using Hexnode on a daily basis to manage our MacOS devices in our environment.
I have been noticed that Microsoft has released a preview of platform SSO on MacOS for Intune & EntraID.
I was wondering if Hexnode is having a development plan the same for Hexnode to integrate with Google Workspace as well?
As there will be a lot of open doors for passwordless authentication on MacOS when it comes to leverage Secure Enclave Key.
https://www.intuneirl.com/implementing-platform-sso-for-macos-a-deep-dive-into-configuration-troubleshooting/
James.
Hey @james-hoang-nguyen , Great query man!
Hexnode has successfully implemented its Google Workspace Integration which is currently being used for the Single Sign-On (SSO) feature known as Hexnode Access. Additionally, we are in the process of integrating Google Workspace password synchronization through LDAP certificate authentication within Hexnode Access. We will keep you updated regarding the public release of this enhanced feature.
As for the implementation of Secure Enclave, we plan to explore it in the future.
I hope this information is helpful. Please feel free to reach out if you have any further questions.
Cheers
Ben Clarke
2 years ago Sep 23, 2024
Hi Ben,
Thanks for your response. The SSO implementation that you mentioned above only works for Gsuite account that users login to the portal for enrollment. The above implementation is a different one below, please check out the below URL.
https://support.apple.com/en-vn/guide/deployment/dep7bbb05313/web
With this implementation, the platform SSO for macOS will not use such secured LDAP, instead they will use the SSO token directly to authenticate to the IdP to login to the MacOS. Is there any specific roadmap / ETA for this implementation?
James.
Hello @james-hoang-nguyen , Thank you for your reply!
The integration with Google Workspace isn’t limited to just enrollment authentication; we’re also using it within Hexnode Access. By configuring your Google Workspace domain in the Hexnode UEM portal, you can easily select this pre-configured domain when setting up the Hexnode Access policy. This makes the login process on your Macs smoother and more convenient for users. Also, in the upcoming updates for Hexnode Access, we’ll be introducing LDAP certificate authentication, which should enhance the experience further.
As for the platform SSO token being used directly for IdP authentication on Macs, it is indeed part of our roadmap, but we have not yet reached a stage where we can commit to a specific timeline.
I hope this clears things up. Let me know if you have any more questions!
Ben Clarke
12 months ago Mar 31, 2025
Hi Ben,
I have noticed that using Hexnode Access is not a good experience to the end users when dealing with Filevault or even with secured LDAP as it will create two layers password (one is the local password ro decrypt Filevault and one is the password from IDP). The only way to overcome this is the platform SSO on MacOS with IDP (Google Workspace).
I would like to request and urge Hexnode team to implement plarform SSO with Google Workspace soon to overcome this challenge.
James.
Hey @james-hoang-nguyen!
We appreciate your feedback and recognize the value of Platform SSO for macOS with Google Workspace. As mentioned previously, this feature is part of our roadmap, and we will certainly bring it to our team’s attention to prioritize it.
Ben Clarke
