plan on trialSolved
Hello, inside partner portal, I have create for my customer a trial account. In which plan this trial will be ? Ultra?
The trial account will be under the plan ‘Ultra’ by default. The user can switch between the plans by navigating to Admin-> License. You can choose the desired plan from the drop-down list next to the ‘Active plan’ option.
Kindly use the help link to know more about the same.
