Password for enabling Kiosk via Remote actions in HexnodeSolved
Hello, i am trying to lock down my device into kiosk, by clicking on the Actions button. But iam unable to find the password for entering the kiosk mode.
The password for enabling the kiosk mode on devices via Remote actions is same as the Hexnode account password. Please note that there should be a Kiosk policy already applied to the device for the kiosk mode to be enabled via Remote actions.
Hope this helps!
Can the kiosk mode be disabled remotely?
You can disable the Kiosk mode on Android devices via Remote actions:
  • Navigate to Manage-> Devices and select the desired device.
  • Click on the Actions button and choose the option ‘Disable Kiosk Mode’.
You can also disable the kiosk mode on devices by:
Please check out the help doc on Disabling Kiosk mode for more info.
