Password protected certificates in AndroidSolved
Can I upload certificate protected passwords for Android configurations? If so, what are the extensions supported?
Yes, you can. Certificates with extensions .p12 and .cer will be installed silently. For the certificates with .p12 extension, a password should be provided along with the uploaded certificate. If the password is correct, the silent installation of the certificate will happen. If incorrect, the user will have to manually install the certificate.
Please find more info on the same.
