OS update in Android during inactive hoursSolved
How to set the OS update in Android to happen at a specific time period? So that the update will happen when the user in not using the device.
  • Please navigate to Policies >Android-> Security-> OS Updates.
  • Click ‘Configure’. From the drop-down list next to the System update settings choose the option ‘Update during inactive hours’.
  • You will have the option to set the time period during which the device is inactive. The OS update will happen during this time interval. Please note to associate targets and save the policy.
Kindly use the help link to know more about the same.
Is it possible to like block the OS update of my Android devices?
I don’t think there is an option to block the OS update for Android phones.
I think postponing the update would be fine as well. I just wanted to prevent the updates until we test out our application in the new update. Is postponing possible?
Hey Tadgh,
You can postpone the OS update of your Android devices by navigating to Policies > New Policy > Android > OS Updates and setting the System update settings option to “Postpone update”. Navigate to Policy Targets and associate the policy to the required devices. This will postpone all further updates for 30 days on the Android devices to which the policy has been associated. This feature works only on devices that are enrolled as “Android Enterprise – Device Owner”.
Hope this clears your query.
Chris Coleman
