OS Update for WindowsSolved
Is there a way to update the OS for Windows devices from Hexnode?
Hi @Lars, currently, you may not be able to deploy OS updates to a Windows PC like you do with the other platforms (Android, macOS or iOS) from the device actions or through device policy, but you can push OS updates to your devices with the help of Windows scripts.
The script to do just that is available on our Script Repository in the Help Center. Please do check the page out.
Once you’ve prepared the script file, you may deploy the script remotely to your endpoints using Hexnode’s Execute Custom Scripts device action from the Manage tab or device page.
Zach Goodman
Thanks @Zach for the links, we’ll use the scripting feature and see if that works out.
  • This reply was modified 3 years, 8 months ago by  Zach.
