After getting the iOS 15 beta, I’ve been having trouble with OpenVPN. It is essentially preventing connection to internet. When I turn off the VPN, these problems go away, but that’s not a permanent solution. Any solutions for this?
OpenVPN issues after iOS 15 betaSolved
Hey @henrietta, thank you for reaching out to us!
This seems to be a common issue being faced by users after updating their devices to iOS 15 beta. In such cases you can try the resolve it in the following ways:
- Configure network access.
- Open the Settings app.
- Navigate to your VPN app settings. You can do so by scrolling down to the list of apps.
- Click on Wireless Data.
- Ensure that WLAN & Cellular Data is opted for the VPN app.
- Turn on and turn off Airplane mode.
- Turn on Airplane Mode. You can do so from the Control Center or the Settings app.
- Wait for at least 30 seconds.
- Turn Airplane Mode back off.
- Check if you can access the Internet now.
If the problem persists, you can try uninstalling and reinstalling the VPN app.
Feel free to reach out to us for any queries!
Kind regards,
Eren Schwarz
We have been having some issues with OpenVPN on our Macs, any way to troubleshoot that?
Hey @abbi, thank you for reaching out to us!
Can you please share the issue you are facing? That will help us narrow down the solution that would be apt for resolving the issue. You can also refer to Troubleshooting client VPN tunnel connectivity and identify a solution for the error.
Hope this helps!
Kind regards,
Eren Schwarz
