OEMConfig for Android EnterpriseSolved
Looking forward to managing Android devices at ease? We got it covered in our latest release.
With Hexnode’s support for OEMConfig, you can now customize OEM specific settings for Android Enterprise enabled devices.
The Configuration Applications build by the OEM vendors are hosted on the Managed Google Play. This can be added to the Hexnode App inventory, which then lists all the possible device settings.
All you need to do is to approve the OEMConfig Apps from the Managed Google Play and customize from the available settings, and you’re done.
Wanna know in detail? Let’s go.
  • Login to your Hexnode portal.
  • Navigate to Apps > +Add Apps > Managed Google Apps > OEM Config > Choose the OEMConfig App > Approve.
  • Now, go to Policies > Android > App Management > App Configurations > Select the OEMConfig App > Customize the settings from the available options > Done.
The OEM vendors who currently manufactures OEMConfig apps includes,
Get to know more on configuring OEMConfig Apps from here.
