Here, we launch a brand new tweak to the enterprise app installation on Windows. This enhanced feature makes MSI app deployment a whole lot easier with command-line arguments. The best part is that you can now pass all the installation specs you need or define the installation behaviour the way you want.
Need no longer worry about where the installation should be initiated on the device. Include device location for installing, enable app logging or force device restart after the install. You can get complete control over the enterprise app deployment via arguments.
Sophia Scott
