I have been evaluating Hexnode for a while, and I would like to know about the migration process, Can anyone help me out?
Migration Guide for switching from another MDM to HexnodeSolved
Replies (8)
There are a few things that you have to consider while migrating from one MDM to another.
Please use the help link to know more about the same in detail.
been planning deployment for my client devices, which is basically android. So, if I am planning to migrate all of my android devices, (it’s currently 100 in number and planning to scale up to 250 in future), what would be the major considerations? They are all for corporate deployment (Currently AE); which makes the migration process a big deal indeed…….
Hey there,
Thank you for reaching out to Hexnode.
First of all, can you please fulfill your requirements?
1. Are your devices enrolled in Android Enterprise via Managed Domain? Or is that via G Suite?
2. What is the Android version of the devices?
This reply was modified 4 years, 9 months ago by
Michelle.
it’s GSuite as all of my user details are stored in gsuite directory. And all are running Android 10.
That looks great!
Since you use a G Suite account, you can initially transfer all your users from the G Suite console to the Hexnode console. This would definitely automate the user creation process, eliminating the requirement of manual user creation.
Now, you may configure Android Enterprise using G Suite, followed by device enrollment. You do have the provision for enrolling the devices in both Profile Owner and Device Owner via G Suite. If you are planning for a BYOD implementation, then ‘Profile Owner’ should be your preference. Else, you may go for ‘Device Owner’ for a complete corporate deployment.
Apart from this, there are other requirements to be addressed before initiating a migration process. The migration process basically goes in three steps.
- Pre-migration phase
- Migration phase
- Post-migration phase
The migration steps to be carried out in each phase are detailed in our migration checklist.
Now, for a smooth transition of Android devices from your previous UEM vendor to Hexnode,
- Remove assets from current MDM and back up required data.
- If you’ve got Samsung Knox devices, create a Knox portal account to automate the enrollment process. For compatible reseller purchased devices, create a zero-touch enrollment portal to achieve automatic enrollment.
- Configure G Suite, Android Enterprise, Samsung KME, and Android ZTE (if you are planning to use these services with Hexnode UEM).
- Sync users from directory services to Hexnode UEM.
- Disenroll devices from current MDM.
- Enroll devices into Hexnode UEM.
Have a look through migrating Android devices for detailed steps.
Thanks a lot. Let me try out the steps and will get back to you.
I have merge two Google Workspace accounts now how i will move to Hexnode.
Hello @rick, welcome to Hexnode Connect!
We might require a few extra details to help you with migration, could you please reach out to our support team for further assistance?
You can email the team at mdm-support@hexnode.com or call them up at our toll-free numbers:
US: +1-833-HEXNODE (439-6633)
UK: +44-8003-689920
AU: +61-1800-165-939
NZ: +64-9-8842599 (Direct)
CH: +41-44-798-2244 (Direct)
Intl: +1-415-636-7555
