Manual Entry in iOSSolved
Ideation
2 years ago
Hello,
I would like to request the ability to the into a kiosk mode enabled iPad manually. The reason is in case one needs to manually connnect to a WIFI hotspot and to power the iPad off manually.
2 years ago
Hello @ooida, welcome to Hexnode Community!
I’m sorry, there’s a slight lack of clarity. Were you talking about being able to perform other actions on iOS devices while they are in kiosk mode?
When it comes to powering the devices off manually, it can be done unless the Disable sleep wake button option under Advanced Kiosk Settings is enabled. But other actions like turning the Wi-Fi hotspot on/off are, unfortunately, not available for iOS devices. We will take it up with the respective teams to see what can be done and we will keep you updated.
Do let us know if this is what you had in mind.
Best Regards
