Make shortcut to speed dial from home screenSolved
I need for a policy to be able to install a shortcut that calls a fixed phone number when opened. I see that Hexnode doesn’t support widgets and the only other solution I can find is make a single-use app to load as an enterprise app. Is there any intended way to do this?
We’re using Samsung Galaxy A13 5G’s.
Hi @Admac. Thanks for reaching out on Hexnode Connect!
Unfortunately, we do not currently support the feature of adding a direct dial shortcut on Android devices.
We shall have a feature request raised on your behalf and keep you in the loop with the updates regarding this. Meanwhile, we’d love to have you post more queries and requests with us.
Chris Wheeler
