List admin accounts on Windows devicesSolved
2 months ago
Hi! Is there a way to get a list of all administrator accounts on my device? Any suggestions?
2 months ago
Hi @wilma!
You can retrieve the list of administrator accounts using a simple command. Run the following in the Windows Command Prompt:
Alternatively, you can use PowerShell with the following command:
2 months ago
Hi @wilma,
The commands suggested by @emersyn are spot on. I’d like to suggest another approach that might be helpful as well. You can use the following PowerShell script to get a detailed list of admin accounts on your Windows device:
If your Windows device is enrolled in Hexnode UEM, you can use the Execute Custom Script remote action to retrieve the list of admin accounts. Otherwise, you can run the script using Windows Terminal.
List of admin accounts
Hope this helps! Let me know if you have any further questions.
Ben Clarke
