Lifeguard working example?Solved
2 years ago
Does anyone have a working example of how to update lifeguard via Zebra MCxx devices? I haven’t been able to get it to work.
We’re currently on Update 98 and trying to get up to U120. Do we have to deploy each one?
2 years ago
Hey Chris Black,
Hexnode allows you to deploy OTA updates to your Zebra devices using the Zebra OEMConfig application. Follow the steps below to configure LifeGuard OTA firmware updates to your Zebra devices.
  1. Approve and add the Zebra OEMConfig app to the Hexnode App Inventory.
  2. Set up the required OEM configurations (Firmware Over The Air Configuration in this case).
  3. Associate the policy with all your Zebra devices.
To better understand how you can configure OTA updates for your Zebra devices, you can go through our comprehensive help doc on how to set up OEM Configurations for Zebra devices.
Hope this clears your query.
Chris Coleman
  • This reply was modified 2 years, 2 months ago by  Chris.
  • This reply was modified 1 year, 12 months ago by  Chris.
2 years ago
Thanks for the link.
2 years ago
Any time, @DianeParsons. Always happy to help!
Check out our blogs on setting up Zebra device management using Hexnode MDM and
how Zebra technologies power work devices for specially tailored rugged applications
too.
