Level up your Windows kiosk experience! Solved
2 days ago
We’ve rolled out a major update to the Multi-App Kiosk mode on Windows, giving admins more control and flexibility in configuring kiosk experiences.
What’s New?
  • Autologon Support
    A local user account is created and logged in automatically on reboot—no manual steps required.
  • Auto-Generated Start Menu Layout
    Skip the manual work—Hexnode now auto-generates a Start menu layout based on the apps added to the kiosk. You can:
      • Customize tile sizes
      • Choose which apps launch automatically at login
  • Advanced Kiosk Settings
    More control over kiosk behavior with advanced options:
    • Access all files (Windows 10)
    • Access Downloads folder (Windows 10)
    • Access removable drives (Windows 10)
    • Windows taskbar customization (Windows 11) – Customize the taskbar, choose which apps to pin, and set their order.
This update streamlines multi-app kiosk management, giving admins the flexibility and control they’ve been waiting for.
Cheers
Eden Pierce
